v.in.ascii
Hi, Dan.
  Compare the eastings and northings in your ascii file with 'good' ascii files
that display. They are probably reversed. If you would like a script I use to
do this (from a related task), let me know. Rick
  I am presently trying to convert lat-lon coordinates into vector maps.
I have successfully converted the data into UTM form with the m.ll2u command
and then put it into grass ascii format using an awk program. I then use the
v.in.ascii command and a vector map is created. This is where I run into
trouble. When I use the d.vect command the map does not display. I tried
other maps that had been create other ways and they work so I don't know what is
wrong. The map that I created is within the region so it should display. If
there is anything that I didn't do or set please respond.
Rick Thompson- Research Assistant E-mail: rick@cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-5736
Ozark Hall Rm. 12 Fax: 575-3846
University of Arkansas
Fayetteville, AR 72701
