v.in.dlg
|I have been trying to read a number of U.S.G.S. DLG-3 optional format
|files into GRASS and seem to be having a bit of a problem doing so. It
|appears that the v.in.dlg (and the v.import) procedures cannot find the
|DLG files. Are the import functions expecting a particular filename or
|does the data have to be in a particular dircetory/location?. I have tried
|all possible combinations and have run out of ideas.
You have to put the DLG files in $LOCATION/dlg. In short if your database
  is /home/data and your location is tennissee, mapset soandso then you
  would put the dlg's in the directory /home/data/tennissee/soandso/dlg
v.in.dlg with then find the files
    __ __
   / ) / / ) Research Specialist
  / / _ /_ _ /__/ Ctr for Advanced Spatial Technologies
  (__/_(_)_/ /_/ )_ / _ National Ctr for Resource Innovations
    / 12 Ozark Hall, Univ. of Arkansas
   / Fayetteville, AR 72701
John E. Parks phone: (501) 575-6159
[john@tang.uark.edu] Internet or: (501) 575-4575
