v.in.dxf in GRASS4.0
Hi.
I have been using the v.in.dxf command to import AUTOCAD DXF files
into the vector format. The points in the DXF file are translated
into the vector file as a set of two points - I am not sure why,
and the manual is not too clear on that.
Also, the points are put into the vector file in the sample format -
P 2
  100 120
  180 120
I could not find a reference to this format in the Programmer's
manual (4.0 changes / 3.0). Can the information not be stored as
site data?
As an aside, the arc import routine does work , though the circle
one does not. (The manual does not promise to translate either of
these.)
Any comments would be a great help.
Thanks.
-Raj
