v.in.dxf
Dave-
Thanks for responding to my dxf import problem. However I still receive the
"segmentation fault" error when importing the dxf as an ascii file. It
recognizes the -a switch, but then fails. This is true with complex files
as well as simple test shapes created on another machine.
Does anyone else have any luck and/or headaches with v.in.dxf? I am running
GRASS 4.1.5 (Kang, ELF) and Linux 1.2.13.
Thanks-
Scott Grover
scottg@horne.com
