I have updated to the latest v.in.shape source, and I am still getting the
same error. I get the following when I run it ...
"vtd42071" successfully opened
Creating dig_att(L) file "vtd42071"
v.in.shape: shp2dig.c:751: partCalcFieldsPolygon: Assertion `fabs(newx1) < 1.0e10 && fabs(newx2) < 1.0e10' failed.
Aborted (core dumped)
The same thing happens whether I use the defaults or smaller for the snap
distance. Should I be setting the resolution lower? I have it set at :01"
now, but I have tried 0:00:00.01 with no difference.
Brian
On Mon, 11 Sep 2000, David D Gray wrote:
Brian
I managed to import your files to the required projection.
1) I used v.in.shape (most recent snapshot - actually with the default
values reduced further). This was imported to a LL location with the
following settings:+40.34
-76.74 -75.85
+39.70NSres 0.001
EWres 0.001Import parameters snapdist=0.0000001 sliver=0.0001
2) Create a UTM location with the following settings:
4465523.252
350836.065 427811.811
4395595.396NSres 5
EWres 5Spheroid airy (you will prob choose something else)
Zone: 18calculated from (1) with m.ll2u
3) In UTM projection, imported the map from the LL location with v.proj
4) Build with scale set to [1:]200
Result:
No unassigned attributes, but quite a lot of unlabelled areas. The map
sems to have many little slivers, cut corners, generally quite poor
topology. Ah well, you get this with shape files (not those made by
GRASS mind youbut most others from the common sources).
I think the bugs that were causing the problems are those that havebeen
fixed since Beta8 was released.David
