Has anyone used v.out.arc successfully? The program exists without error messages when I try to
run it. I looked for an updated version on the moon, but a only found a GmakefileThanks,
Katarina------------------------------------------------------------------------------
Katarina Johnsson e-mail: kjohnsso@alder.pfc.forestry.ca
Advanced Forest Technology Lab phone: (604) 363-6017
Pacific Forestry Centre fax: (604) 363-0775
Forestry Canada
Victoria, BC
Yes !
I have used it successfully. The are only two tricky things about using it.
1. The ungenerate files have to be placed under the directory
"$LOCATION/arc/"
2. Sometimes the hint about which id-column you should use is wrong if you
used the program interactively. Examine the txt file yourself first
to be sure which id-column to use,
Lars
Lars Schylberg Email: larss@fmi.kth.se
Department of Photogrammetry
Royal Institute of Technology Tel. +46 8 790 86 33
S-100 44 STOCKHOLM, SWEDEN Fax. +46 8 790 66 10
Sorry about my message this morning ! I was speaking about v.in.arc.
I have not tested v.out.arc.
Lars
