v.out.points
"In an E-mail message, dnickisc@chief.ecn.uoknor.edu said:"
I am attempting to create a surface over digitized elevation contours. The problem is that s.surf.tps requires a sites file and I have a line file. I believe
that v.out.points makes the necessary conversions, but I have been unable
to find v.out.points on the moon or any documentation on the topic. Any help
would be greatly appreciated.
Daphne Nickisch
Daphne,
Perhaps you're referring to "v.to.sites"? Also, there are a couple
other surface generating programs in GRASS. First, you'd have to
run "v.to.rast" on your vector contour line file. Then you can
run "r.surf.contour" if you have continous contour lines (that is,
there aren't any breaks in the contour lines where you'd put text
labels). If your lines aren't continuous, you could try "r.surf.idw"
and "r.surf.idw2". The GRASS 4.0 manual has pages for all of these
programs.
Here's a list that I got from Michael Shapiro and a brief blurb
as to how they go about generating surfaces:
Inverse distance weighted interpolation:
  r.surf.idw grid posted points
  r.surf.idw2 grid posted points (different search method)
  s.surf.idw non-grid posted points
Contour interpolation from rasterized contours
  r.surf.contour
Thin plate splines with tension (helena's work)
  s.surf.tps
The word here at CERL is that the "s.surf.tps" beats all.
