In an E-mail message, James Darrell McCauley wrote:
Q: Should there be a problem in using v.out.sdts with vector maps that
are not in your current mapset?
It is true, alas, that the current version of v.out.sdts requires that the
vector map you convert to SDTS format format be in your mapset. This seemed
to be the simplest and cleanest solution to the problem of SDTS export when
we designed the program; later versions may be more flexible in this regard.
BTW, I have software that serves up all of our GRASS vector data in
SDTS format via WWW. If you'd like to check it out (and provide
feedbackit can be found at:
Hooray! I am glad to see that the GRASS/SDTS software is getting some use.
David Stigberg email: stigberg@zorro.cecer.army.mil
USACERL phone: (217) 352-6511 x7401
P.O. Box 9005 fax: (217) 373-7222
Champaign, IL 61826-9005
