v.patch output (fwd)
Hello
I am running GRASS 4.0 and created a map of a Caribbean island in v.digit.
The map was on two sheets, and were therefore joined with v.patch. I then
ran v.support on the patched output (soils) before copying it with g.copy
to another file (topo). I then edited the new file (topo) in v.digit with
the "no digitizer" option. The edited (topo) file could be viewed with
d.vect, however, when I went back into v.digit this time specifying the
Calcomp digitizer, no map appeared when the screen was eventually redrawn.
I then decided to remove the new file (g.remove) but got the following -:
  REMOVE [topo}
  raster missing
  header missing
  category missing
  color missing
  history missing
  misc missing
A g.list revealed that topo had NOT been removed after all.
Could someone please show me where I am going wrong?
Thanks
Lesley-Ann Dupigny.
Having had to delete the odd vector file myself - you need to specify that it is
vector, (the default is raster). Try
                g.remove vect=topo
With the digitizing problem - I can't help. I have had the odd line not
appear when GRASS and I both know it is there. It came back up when I
redigitized over the top of it. Have you tried v.digit on the vector file you
copied from?
On Wed, 8 Dec 1993, Lesley-Ann Dupigny wrote:
Hello
  REMOVE [topo}
  raster missing
  header missing
  category missing
  color missing
  history missing
  misc missing
Thanks
Lesley-Ann Dupigny.
In info.grass.user you write:
Hello
REMOVE [topo}
raster missing
header missing
category missing
color missing
history missing
misc missing
Thanks
Lesley-Ann Dupigny.
You probably typed g.remove topo (which assumes topo is raster file)
you should type g.remove vect=topo.
BTW: Am I right that you are using grass4.0, and not grass4.1?
Olga
