%%From: "Mike Hanratty" <hanra001@gold.tc.umn.edu>
%%Has anyone encountered this problem with the SCS contributed module v.proj?
%%When I try to convert from Albers Equal Area to another projection, I get the
%%following error message:
%%major axis, radius = 0, or not spec'ed
%%cannot initializa pj
%%If anyone has a fix for this I would greatly appreciate it, since my STATSGO
DLG
%%files are in this projection.
%Minneapolis, MN 55414
I would bet that the spheroid is not defined in the PROJ_INFO file under
the PERMANENT mapset --or-- that proj does not recognize the information
in an existing PROJ_INFO file. The NRCS v.proj code requires the USGS proj
4.0 code --not the code under src/libes/proj.
The projection libraries may need rebuilding using src.contrib/SCS/libes/proj
Jill
____ __ ________ _____ _______ .
/ \ // /____// / / ____/// /.....\/\ /\
/ \// / \\ / // / \_/\_/ \
_/ \/__/ \\_/_____\ /_____ // /\/ _/\ ---------
________________________________________/
Jill R. Schuler
USDA
Natural Resource Conservation Service
2627 Redwing, Suite 120
Ft. Collins, Co 80526
VCOMM:9010-2418
e-mail: jschuler@ftc.nrcs.usda.gov Phone: (970) 282-2418
