v.proj, projection from lat/lon to tmerc
hi,
i have a problem with v.proj (in grass 4.3 and grass 4.2.1).
I want to make a grid for the german messtischblaetter, which are always
sized 00d10' x 00d06', in gauss-krueger projection (transverse
mercator). So my idea was to create the grid with v.mkgrid in a lat/lon
location and use v.proj to project that vector file to my gauss-krueger
location.
But the projection does'nt work as expected:
my lat/lon location:
projection: 3 (Latitude-Longitude)
zone: 0
north: 52N
south: 49N
east: 10:30E
west: 7:30E
nsres: 0:00:05
ewres: 0:00:05
rows: 2160
cols: 2160
(vector file from v.mkgrid is ok, did run v.support and did a v.alabel)
my gauss-krueger location:
projection: 99 (Transverse Mercator)
zone: 0
north: 5763000
south: 5430000
east: 3600000
west: 3390000
nsres: 250
ewres: 250
rows: 1332
cols: 840
and the boundary of the projected vector file:
zone: 0
north: 3582
south: 3372
east: 277
west: 148
nsres: 26.25
ewres: 25.8
rows: 8
cols: 5
If i set the location to the above values i can display a vector file
that resembles the desired shape.
The PROJ_INFO files are correct (false easting for gauss-krueger is
350000).
What's wrong with my attempt or with v.proj?
If i calculate a sites file for the corners and use PROJ.4 (external to
grass) to project them to gauss-krueger everything is fine.
many thanks in advance for an answer,
Andreas Lange
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
