Hello all,
I am having difficulties in reprojecting vectors (from lat/lon to albers).
Could someone please advise me as to what might be causing the problem?
Here are the steps :
v.proj
v.support
The projection appears to run without any errors. When I run v.support,
I get the following error messages :
GRASS 4.11 >> v.support r_10
V.SUPPORT:
Selected information from vector header
Organization:
Map Name: from raster map rcomb
Source Date:
Orig. Scale: 100000
No snapping will be done
Reading Vector file.
100%
Building areas
Building islands
Attaching labels
Bad line 'LAB2÷¹|äÁ XÿÁB/½ -1771529.3476489484 2385391.4491144288 10
Bad line 'LAB% ï3]Á;PýÁB/½ -1789979.6952772755 2378259.8678039745 10
Bad line 'LAB"¡»ÜÒÁ;a¥ ùÌÁB/½ -1794469.0389678814 2377027.4676674390 10
Bad line 'LAA¨aÝÁ<_ ߢÏÁB/½ -1859360.1245061641 2314434.0391399697 10
WARNING: line 1 label: 10 matched another label: 10.
Number of lines: 30
Number of nodes: 30
Number of areas: 0
Number of isles: 0
Number of atts : 26
Number of unattached atts : 0
Snapped lines : 0
Mapset <or> in Location <us_albers>
When v.support is executed on other non-projected vector files, there appear
to be no errors (so far). As far as I can tell, the errors appear only
after reprojecting. I suspect v.proj.
GRASS was compiled from scratch and we are at update package 4. We also
downloaded the file "mapgen.tar.Z", created a src.related directory, and
compiled mapgen and proj.
I noticed there is a v.proj directory in src.alpha/mapdev. There is also
v.proj in the src.contrib/SCS/vector directory as well. Could there
be a conflict here in the compilations? Or perhaps there is
some type of conflict between the v.proj and mapgen/proj compilations.
(I have been following the discussion about SCS proj and USGS proj)
Thanks in advance,
Wayne Gibson
Oregon State University
