v.proj
HELP!! I can't get v.proj to work I keep getting an error message that reads
       major axis = 0, or not spec'ed cannot initialize pj.
I'm trying to take a vector map from utm proj. to aea proj. What am I doing
wrong??
Thanks for your help in this matter. Teresa Salyer
<salyer@tiaer.tarleton.edu>
Teresa,
        Are you certain ALL information in the PROJ_INFO and PROJ_UNITS
files are correct for both GRASS locations? these files should be
located under the $LOCATION/PERMANENT directory of both the UTM and
the AEA "GRASS Locations"... just a shot from the hip :slight_smile:
good luck
        brian
wrong??
R. Brian Culpepper Research Specialist
Center for Advanced Spatial Technologies (fax) 501 575-5218
Rm. 12 Ozark Hall 501 575-6159
University of Arkansas brian@cast.uark.edu
Fayetteville, AR 72701 Home Page: http://cast.uark.edu
