Does your work with gshhstograss show that there is an improvement that could
be incorportated into several routines used in GRASS to speed up the display
of layers? Has some entity taken responsibility to be a clearing house for
new developments in GRASS?
I discussed my experience with some colleagues and we decided, without looking
inside the code, that the problem is probably in the indexing method used
by the
grass vector programs - I suspect that some kind of (exhaustive) search is
being
done on the polylines, repeatedly, which scales exponentially with the
number of nodes
on the polylines. There is probably also a "bounding box" for each segment.
My solution, to break long ones up into adjoining segments, means that
using the
bounding-box for indexing is more efficient, and then searches of the nodes
on a segment
is shorter. I have no idea what the optimum number of nodes would be and
it probably
depends on the spacing and tasks in hand. However, it might be worth
incorporating
into the "v.in.anything" programs an option to split up the long polylines
at that
stage, then the downstream problems would be gone.
To my knowledge, continued coordination of GRASS is in the hands of Rutgers
and LAS,
but neither appears to be too pro-active about this.
Simon Cox
_________________________________________________________
Dr Simon Cox __ \
CSIRO Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ;-' \ Geodynamics
Nedlands, WA 6009 Australia ( \ Cooperative
T: +61 9 284 8443 + ___ / Research
F: +61 9 389 1906 L~~' "\__/ Centre
simon@ned.dem.csiro.au W
http://www.ned.dem.csiro.au/AGCRC/people/CoxSimon/
