Hi Pierpaolo,
I attempted to import the DLG format generated by Arc/Info and had no luck.
Check out the GRASS Users FAQ for importing to GRASS from Arc/Info using the
ungenerate function. Another transfer format that might be faster and less
trouble is SDTS. I have not complied the SDTS source code and tried this, but
it looks like the potential is there. The FAQ URL address is:
http://www.cecer.army.mil/grass/faq.html
I have imported in GRASS a vector file in DLG format from ARC/INFO, I
have create a directory called DLG in my mapset, I ran v.in.dlg and
d.vect without troubles but when I ran v.support I got the following
message:
Segmentation fault-core dumped!
Does anybody know the solution or the reason?
How could I resolve this problem with v.support?
I hope this helps.
Louis Clarke U.S. Army Corps of Engineers
lclarke@alb-co-r.swa.usace.army.mil Albuquerque District
voice (505)342-3281 Regulatory Branch
fax (505)342-3498 http://www.swa-wc.usace.army.mil/reg/
