I have been a user of GRASS4.0. Recently I installed GRASS4.1 on SUN SPARCipx.
The command v.support makes an error message as follows. That is after the
execution of v.in.arc or v.in.ascii.
Mapset <PERMANENT> in Location <reihoku19>
GRASS 4.1 > v.support
VECTOR (DIGIT) FILENAME
Enter 'list' for a list of existing binary vector files
Hit RETURN to cancel request
10-2id8
<10-2id8>
Selected file is [10-2id8]
1 - Build topology information (Needed for digit)
2 - Edit the category file
Enter a number <1-2>
anything else to quit: 1
Do you want to snap nodes to other nodes within a threshold (y/n) [n]
V.SUPPORT:
sh: 2886 Memory fault
ERROR(v.support): Could not build vector file: '10-2id8'
GRASS 4.1 >
Please give me any information to settle the error. Thank you for your kindness
Iwao Noda
Research Scientist
Forest Management and Economics Laboratory
Kyushu Research Center
Forestry & Forest Products Research Institute
Kurokami 4-11-16, Kumamoto 860, JAPAN
Fax: JAPAN(096)344-5054
Internet : noda12@ffpri-kys.affrc.go.jp
