Dr. Lobo,
Hopefully this will help you. Enter v.digit and try to relabel the pro
blem areas OR digitize in a line and then immediately remove the same line. Wh
en exiting v.digit, ANSWER YES TO "DO YOU WANT TO COMPRESS THE ATTRIBUTES FILE?
" If you enter v.digit and nothing on your layer is changed then the attribute
question will not appear. That is why you may want to fool v.digit by digitiz
ing in a line and then removing it. Then run v.support and with any luck you w
ill not receive the pnt_to_area message. I
had this same problem, and this seemed to work for me. Good Luck.
Linda at DECAM
