v.support problems
In an E-mail message, mike camann wrote:
Hmmmm....
Judging by the absence of response to my request that anyone with a
working v.support [build] under Solaris 2.4 contact me, it appears that
vector topologies cannot be built on Suns that run this newest version
of the OS. Is there any plan at CERL to fix this, perhaps in the next
update (or in release 4.2)? I hope to take a whack at it soon, myself,
because lack of vector capability is currently crippling my research on
such a machine, but 1) it may be some time before I can commit much
time to the problem, and 2) figuring out the unsupported vector library
calls that _appear_ to be responsible looks non-trivial, especially
since I'm presently working from a remote, X-terminaled environment
that was never designed for efficient debugging. So far, my best
weapon has been adding a slew of embedded printf()'s and recompiling to
try and trace the problem through the convolutions of the Vlib-- not an
optimal solution!
Is there anyone else out there who is also attempting to fix this?
Michael Camann camann@dial.pick.uga.edu
Department of Entomology camann@sparc.ecology.uga.edu
University of Georgia (706) 542-2303 voice
Athens, GA 30602 (706) 542-2640 FAX
Calm down Mike. Much as we like, we don't have unlimited resources.
If you have any SunOS-compiled v.support code, use that in place of
the Solaris2.4 code. I've found no problems with some, admittedly short, testing
of SunOS compiled grass on Solaris2.4 machines, so v.support may work.
Also, submit a bug report.
I am planning to compile and test Grass4.1.5 under 2.4 late this week or next
week.
Paul Loechl loechl@diego.cecer.army.mil
USA CERL (217)352-6511x7668
