v.support VERY slow
Eric:
Don't be suprised if it takes 5 days, not hours...
I have some experience in importing dlg files to grass vect
on a well-outfitted sparc 2. Seems to me it took v.support
close to 5 days to do topology on a road map of the St. Louis area.
However, this was a machine I share with others, so I run
a script to do the importing and I use "nice +15" so that
I don't bog the machine down when other things are happening.
As long as the disk space holds and no one reboots the machine,
et cetera, it is no big deal. I have the script capture stdout
and stderr to a file for reference and then it sends mail when
maps are done.
From lists-owner@amber.cecer.army.mil Wed Aug 5 20:14:29 1992
From: kostello@muir.sscnet.ucla.edu (Eric Kostello)
Subject: v.support VERY slow
The subject is really:
v.support is very slow even on a Sparc 2 on files derived
from Los Angeles County TIGER Files....
I imported the Los Angeles County TIGER file with v.in.tiger
then ran v.support. The tutorial for "TIGER in GRASS" warns that
this may take up to several hours, but it has taken nearly 48
hours and it's still not done.
System Configuration:
Sparc 2, 48MB RAM, Plenty of disk space.
Running under OpenWindows
It wrote the file la.Master after about 30 hours in the dig_att
directory.
What I really want to know is whether this is normal for huge
(e.g. 65MB for type 1) TIGER files or if something has gone
awry. I'm a new GRASS user and we just got GRASS running here
so there may be some problems with our configuration.....
Any advice on this will be greatly appreciated.
Thanks.
Eric Kostello
