What does the following message means?
Does it mean that the label of area 244 (which is 273)
is the same that the label of area 274?
v.support usos.proj_v
V.SUPPORT:
Selected information from vector header
Organization:
Map Name: usos_v
Source Date:
Orig. Scale: 0
No snapping will be done
Reading Vector file.
100%
Building areas
Building islands
Attaching labels
WARNING: area 10116 label: 1 matched another label: 258.
WARNING: area 244 label: 273 matched another label: 274.
WARNING: area 9981 label: 4200 matched another label: 4213.
Number of lines: 27150
Number of nodes: 18291
Number of areas: 10116
Number of isles: 1257
Number of atts : 10115
Number of unattached atts : 0
Snapped lines : 0
Thanks
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Marti Franques s/n
08028 Barcelona (Spain)
tel. 34 3 330 2716
fax. 34 3 411 0012
alobo@ija.csic.es
alobo@eno.princeton.edu
