v.support
Hello,
I have a problem when I am running v.support for
a vector file that I have imported using v.in.ascii.
There are two adjacent polygons in the file which share about
four points. The coordinates in the attribute file definitely
fall within each polygon. When I run v.support, I get the
error message
PNT_TO_AREA FAILED ...
for both polygons and attributes. However, if I create two
separate ASCII vector files each with one polygon and one
attribute, I can successfully run v.in.ascii and v.support.
Has anyone had a similar experience or know why this is
happening? The points that the polygons share are identically
the same in each polygon list.
Thank you,
Brian
Brian Connelly
College of Forest Resources phone: (206) 543-5506
University of Washington AR-10 FAX: (206) 685-3091
Seattle, Washington 98195 e-mail: bac@hardy.u.washington.edu
