v.to.rast and v.in.dxf
Hello GRASS-users,
I want to utilize the routine v.to.rast ( with v.support ), but
I digitized the vector data sets as dxf format of Autocad.
Now, v.in.dxf works well, into dlg format.
v.support and v.to.rast are working, but dig_plus and dig_att
files concerned are not generated. Therefore, just blanks in d.mon and d.rast.
What version of GRASS are you using. I have been trying to import a
dxf file using v.in.dxf. It reads the file, says 100% complete, but
does not generate the dig or dig_att files. This is a new region with
no other files. Could it have something to do with my region definition?
According to GRASS manual, it is shown that v.digit with digitizer connected
with GRASS is needed to do that. Is that only way to v.to.rast ?
You can use v.digit without a digitizer by selecting <none>, however, you
may have to compile v.digit if you didn't previously because you had no
digitizer.
A
Therefore, my problem is
v.to.rast without v.digit... How ?
Anyone help me .
Thanks in advances.
                                                  K. Lee
kilee@ccu.umanitoba.ca
Looking forward to response.....
