v.to.rast failures ( and related? v.support problem)
I have two interrelated problems.
1. I have a vector layer consisting of a bunch of areas.
  When I do a v.to.rast, some of the areas don't transfer.
  I've checked with d.what.vect and some areas have a value
  on the vector version, but on the raster they have
  become (0) meaning nothing.
  What could the problem be?
2. On another vector layer of areas, the v.to.rast works fine.
  Except that after I do a "v.support option=build" a few
  areas dont transfer. The output looks like this:
WARNING: area 5 label: 3 matched another label: 3.
WARNING: area 32 label: 4 matched another label: 4.
WARNING: area 3 label: 2 matched another label: 2.
PNT_TO_AREA failed: (693691.590762, 3959246.402942) (Category 2)
PNT_TO_AREA failed: (693700.923745, 3959055.076807) (Category 3)
PNT_TO_AREA failed: (693685.767299, 3959246.756544) (Category 2)
Number of lines: 113
Number of nodes: 90
Number of areas: 32
Number of isles: 10
Number of atts : 35
Number of unattached atts : 3
Snapped lines : 0
  The areas that dont transfer are the "PNT_TO_AREA" failures
  which makes sense, but why does it work if I DON'T do
  v.support?
  Sometimes it seems to help to use v.digit to break,remove,
  snap, label the areas, but only some times.
  Why do some labelled areas become unlabelled (unattached atts)
  when I do a v.support?
  And what does the WARNING: area 5 .. mean?
  /////// Bjorn Svensson
  / <---@ Department of Geography
  | > University of California, Santa Barbara
  | < Santa Barbara, CA 93106, USA
  | __X
  \ | e-mail : bjorn@geog.ucsb.edu
In info.grass.user you write:
Number of nodes: 90
Number of areas: 32
Number of isles: 10
Number of atts : 35
Snapped lines : 0
v.support?
| __X
About problem number 1 I will post a message in a second
About problem number 2:
Please ftp this map to me
(moon.cecer.army.mil) grass/incoming directory
I would like to look at this vector map.
Olga
