Please replace file do_areas.c in v.to.rast directory
by the file
_______________-cut here-___________________________
#include "digit.h"
#include "gis.h"
static
struct list
double size;
int index;
int equal;
CELL cat;
} *list;
static int nareas ;
do_areas (Map, Points)
struct Map_info *Map;
struct line_pnts *Points;
int i,index, k, equal;
CELL cat, last_cat;
static struct line_pnts *Last_Points = NULL, *tmp_Points = NULL;
int comp_double();
if (nareas <= 0) return 0;
if(!Last_Points)
Last_Points = Vect_new_line_struct();
if(!tmp_Points)
tmp_Points = Vect_new_line_struct();
for (i = 0; i < nareas; i++)
index = list[i].index;
cat = list[i].cat;
set_cat (cat);
if(Vect_get_area_points (Map, index, Points) <= 0)
fprintf (stderr, "*** Get area [%d] failed ***\n", index);
return -1;
if((list[i].equal<0) /* if we never checked area against previous area */
&& (list[i].size == list[i-1].size)
&& (Points->n_points == Last_Points->n_points) )
/* check if the area is the same as the last area */
list[i].equal = 1;
/* copying Points to tmp_Points */
dig_alloc_points(tmp_Points, Points->n_points);
tmp_Points->n_points = Points->n_points;
for(k=0;k<Points->n_points; k++)
tmp_Points->y[k] = Points->y[k];
tmp_Points->x[k] = Points->x[k];
printf("%f %f %f %f\n", Last_Points->x[k], Last_Points->y[k], tmp_Points->x[k], tmp_Points->y[k]);
if(G_projection() == PROJECTION_LL)
tmp_Points->x[k] =
G_adjust_east_longitude(tmp_Points->x[k], -180.);
Last_Points->x[k] =
G_adjust_east_longitude(Last_Points->x[k], -180.);
/* Adjusting eastings to be from -180 to 180 */
/* sorting because points might be in different order */
Last_Points->n_points = Points->n_points;
/* since areas might start and end with different point,
and since first and last points are the same, we skip the
first point in both areas */
qsort(Last_Points->x + 1, Last_Points->n_points - 1, sizeof (double),
comp_double);
qsort(tmp_Points->x + 1, tmp_Points->n_points - 1, sizeof (double),
comp_double);
qsort(Last_Points->y + 1, Last_Points->n_points - 1, sizeof (double),
comp_double);
qsort(tmp_Points->y + 1, tmp_Points->n_points - 1, sizeof (double),
comp_double);
if(k>0)
if(Last_Points->y[k] != tmp_Points->y[k]) list[i].equal = 0;
if(Last_Points->x[k] != tmp_Points->x[k]) list[i].equal = 0;
Last_Points->y[k] = Points->y[k];
Last_Points->x[k] = Points->x[k];
} /* checking if area is the same as previous area */
else
list[i].equal = 0;
dig_alloc_points(Last_Points, Points->n_points);
if(list[i].equal == 1)
fprintf(stderr, "WARNING! There are 2 identical areas in your map\n");
if(!cat && !last_cat)
fprintf(stderr, "both of them unlabeled\n", cat);
continue;
if(cat == last_cat)
fprintf(stderr, "both of them are labeled %d\n", cat);
continue;
if(cat && last_cat)
fprintf(stderr, "one of them is labeled %d another one is labeled %d\n", last_cat, cat);
fprintf("ignoring the area labeled %d\n", cat);
continue;
if(last_cat)
fprintf(stderr, "one of them is labeled %d another one is unlabeled\n", last_cat);
printf("Ignoring the unlabeled area\n");
continue;
fprintf(stderr, "one of them is unlabeled another one is labeled %d\n", cat);
/* don't skip here, go to drawing area */
} /* processing equal areas */
last_cat = cat;
G_plot_polygon (Points->x, Points->y, Points->n_points);
return nareas;
sort_areas (Map, Points)
int i,index;
CELL cat;
int compare();
double G_area_of_polygon();
G_begin_polygon_area_calculations();
/* first count valid areas */
for (nareas = 0, index = 1; index <= Map->n_areas; index++)
if (area_ok(Map, index, &cat))
nareas++;
if (nareas == 0) return 0;
/* allocate list to hold valid area info */
list = (struct list *) G_calloc (nareas, sizeof (struct list));
/* store area size,cat,index in list */
for (i = 0, index = 1; index <= Map->n_areas; index++)
list[i].index = index;
list[i].cat = cat;
return -1;
list[i].size = G_area_of_polygon (Points->x, Points->y, Points->n_points);
i++;
/* sort the list by size */
qsort (list, nareas, sizeof(struct list), compare);
/* initialize equals */
if(i==0) list[i].equal = 0;
else list[i].equal = -1;
return nareas;
static
compare (a, b)
struct list *a, *b;
if (a->size < b->size)
return 1;
if (a->size > b->size)
return -1;
return 0;
static int
comp_double(i, j)
double *i, *j;
if(*i < *j)
return -1;
if(*i > *j)
return 1;
return 0;
static
area_ok(Map, index, cat)
CELL *cat;
int att;
if (!AREA_ALIVE(&Map->Area[index]))
return 0;
att = Map->Area[index].att;
if (att == 0)
*cat = 0; /* unlabeled */
else
*cat = Map->Att[att].cat;
return 1;
