v.to.rast
Region settings were ok, and I tried r.compress etc. Both files are
compressed automatically by GRASS, but the compressed file size is slightly
different, although the data is absolutely the same. Perhaps GRASS uses two
different ways to compress the data.?
Stefan
Assuming that Stefan didn't change the region parameters in between the
two displays, the only thing I can think of is that the first version
(created by v.to.rast) is uncompressed, while the second (created by
r.mapcalc) is compressed. Note that I didn't check this out...
Martijn van Leusen
On Mon, 7 Mar 1994, Stefan Jaeger wrote:
> Hi, I'd like to ask if someone else experienced the following problem. I
> digitized polygons and subsequently converted them to a cell map with
> v.to.rast. When I use d.rast to display the map, the display process is
> extremely slooooow. After performing the r.mapcalc operation r.mapcalc 'a=b'
> (just to produce a new map with the same values) the display process is much
> faster. Why is this?
> Stefan Jaeger currently at
> Dept. of Geography USGS
> University of Heidelberg National Center
> INF 348 Reston, VA 22092
> 69120 Heidelberg USA
> Germany
> stefan@geo0.geog.uni-heidelberg.de sjaeger@resdgs2.er.usgs.gov
> ********* sorry, no fancy name tag *********
