v.to.rast
Hello all!
I have a fairly large vector file containing field boundaries in a
specific county. I am currently trying to convert this vector
file to a raster using v.to.rast. I do the following:
g.region vect=flds.vector res=1
v.to.rast input=flds.vector output=flds.vector.out
After conversion, however, the resulting raster file is *mostly*
empty. With only certain fields in color (and the rest white).
I've *checked* the attributes file of the vector map and it
contains some 902 entries, but when I do a v.stats on my fields
layer, I get:
| Format: Version 4.0 (Level 2 access) (Portable)
| Number of Lines: 2775
| Number of Nodes: 1865
| Number of Areas: 916 (incomplete)
| Number of Isles: 23 (incomplete)
| Number of Atts : 896
I've tried running v.support, but I can't seem to get that
"(incomplete)" notice
to go away. Does anyone have any idea as to what my problem is and
whether
or not it can be fixed so I can finally get this vector map in raster
format?
*Any* help is appreciated. Thanks in advance.
Take care.
Clifton B. Wood
Programmer/Analyst for Virginia Tech's AGNIS Department
-------------------- Thought of the Day --------------------
windows95 = n. 32 bit extensions and a graphical shell for
a 16 bit patch to an 8 bit operating system originally coded
for a 4 bit microprocessor, written by a 2 bit company that
can't stand 1 bit of competition.
