v.to.sites and v.plant
From grass-lists-owner@moon.cecer.army.mil Fri Oct 27 15:36:36 1995
Subject: v.to.sites and v.plant
Sender: grass-lists-owner@moon.cecer.army.mil
Reply-To: grassu-list@moon.cecer.army.mil
To: grassu-list@max.cecer.army.mil
Date: Fri, 27 Oct 1995 15:51:33 -0400 (EDT)
X-Mailer: ELM [version 2.4 PL23]
Mime-Version: 1.0
Content-Type> : > text/plain> ; > charset=US-ASCII>
Content-Transfer-Encoding: 7bit
Content-Length: 623
We have digitized straight lines that need to become rasters and
thought we could easily do this with v.to.sites with -a and -i option and
s.menu. Options don't work, though. We ftp'd v.plant from incoming and it too
gives us an error saying can't read dig-ascii header. I am very confused
because I thought I would just make an dig_ascii file myself and
reverse the columns and edit to a sites file format, but all the vertices
are not being output in the dig_ascii file. My lines look great and I
digitized at default threshold, so I should have LOTS of vertices.
Anybody else seen this?
Any and all help appreciated--
You may want to check out v.in.transects which accepts ascii input to create
areas from point data. You will need to give each an azimuth and define the
dimensions of the transect, not difficult at all.
The form is:
1:682635:4344636:202:0.0:0.0:$RES:$RES:81
Then run v.to.rast to get your raster map.
Bill Jackson jackson@sierra.cecer.army.mil
LL-N
USA-CERL
