I'm running v.trim on a map generated from the Census Bureau's TIGER files,
using a trim factor of 0.0 because I only want to eliminate unnecessary
nodes, not remove any lines. The output file, however, has all single
polygon islands missing. I've tried it in GRASS 4.0 on both a Sun IPC and
Intel 386 system with the same results.
Why?
Bruce Nielsen VOICE: (317) 290-3211
GIS/Computer Specialist FAX: (317) 290-3225
USDA-Soil Conservation Service INTERNET: bnielsen@in1000.attmail.com
6013 Lakeside Blvd.
Indianapolis, IN 46278
