Hi. I've been trying
to use v.trim on a vector map
in order to get rid of all
excess nodes. To do this,
a trim value of zero should
be used, otherwise "small
spurs", will be deleted
also. At this point, all
that I want to work with is
the nodes. However, the resulting
output map is only a small
portion of my original map.
Why isn't the rest of the
map being run through the
v.trim process?
Amy Keeley
akeeley@ncdc.noaa.gov
