Has anyone written a command v.what? It should give the
category/attribute of -a the area within which a point falls,
or -l the nearest line/area-edge to the chosen point.
ie a non-interactive version of d.what.vect.
r.what already exists in the grass distribution.
I have hacked together s.what based on some bits passed on to
me by Sue Huse at Berkeley. Only v.what is missing!
Needed to make GRASSLinks a bit more functional.
On another issue, I finally got around to cleaning up and documenting
r.proj, s.to.cell, v.plant which I produced over the last year.
These can be downloaded from
ftp://ftp.ned.dem.csiro.au/pub/r.proj.tar.gz etc
I would like to put files containing a note to this effect on moon
in incoming, but until someone helps me clean off the existing
files with these names (placed there by me earlier!) I can't write
over them!
Cheers Simon Cox
_________________________________________________________
Dr Simon Cox __ \
CSIRO Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ;-' \ Geodynamics
Nedlands, WA 6009 Australia ( \ Cooperative
Phone +61 9 284 8443 + ___ / Research
Fax +61 9 389 1906 L~~' "\__/ Centre
simon@ned.dem.csiro.au W
AGCRC info>> http://www.ned.dem.csiro.au/AGCRC/
