Paola Lecca wrote:
Dear listers,
I obtained some vector files, changing MIF files (MapInfo TAB) firstly into shape files and secondly into GRASS vector files with the command v.in.shape. I'm using the last modified version of this command (version of few weeks ago).
Using v.to.rast, I obtained their raster version. When I visualize it, in many cases I see that the raster doesn't fill the entire space into the vector boundaries. In other words, the raster map doesn't cover the whole area contained by the vector lines.
What kind of problems can the vector map have ?
Is there anyone that has dealt with similar problems and that might help me ?
Thanks in advance.
Paola.
If you need only raster you can try r.in.shape.
Radim
