From owner-grassu@isis.cecer.army.mil Sat Dec 14 01:19 eur 1996
X-Authentication-Warning: isis.cecer.army.mil: listserv set sender to grassu using -f
From: Giovanna Ranci <ranci@quercia.elet.polimi.it>
Subject: VARIANCE OF ANGLES
To: grassu@cecer.army.mil
Date: Fri, 13 Dec 96 19:35:28 MET
Mailer: Elm [revision: 70.85]I need a FORMULA to calculate VARIANCE when arguments are ANGLES (in degree).
For example, I need to calculate variance of aspect map in 3x3 neighborhood.
Aspect is expressed in degrees. It's clear that a cell with value 5 and a cell with value 355 are almost the same aspect so variance formula has to consider it.
I got already a formula with sin and cosine but there should be some mistakes in it
(I calculate variance using command r.mapcalc and r.neighbors but results are strange...definetely unreal. I'm sure error is in the formula not in my procedure in Grassland).
If somebody knows the rigth formula, I will be glad to receive it.
Thanks,Giovanna Ranci Ortigosa
e-mail: ranci@quercia.elet.polimi.it
It's a long time since I had trigonometry at school, but isn't it possible
to recalculate the aspect map in radians and calculate the variance from
that?
Philip Verhagen
philip@raap2.ivambv.uva.nl
R A A P
Plantage Muidergracht 14
1018 TV Amsterdam
The Netherlands
tel: +31 (20) 421 62 00
fax: +31 (20) 421 42 90
http://raap2.ivambv.uva.nl/home_eng.html
