vect polygons to MapInfo
Has anyone done this before? Since MapInfo
needs a polygon/region self-contained
no matter where it shares boundaries with
others or not, it won't take GRASS vector
polygons exported in v.out.ascii?
I have put a program called v.out.mif on the incoming directory of
moon. It makes a mif and a mid file from a grass vector map (polygons
only).
The resulting files are stored in the directory $LOCATION/mapinfo.
If you have rasterized the vector map with grass and you have
assigned colors to the different categories you can use this raster
map to color the exported vector map.
The header of the mif file contains information on the projection
and type of coordinate system used. Since I only use the Dutch
coordinate system, you will have to edit this if you want another one.
The coordinates are written in the format %10.1lf If you need another
format, edit the source.
MIF files can also be imported into Arc-View. There is a tool
MIFSHAPE, which converts MIF-files to Arc-View SHAPE files.
Wish you all good luck and best wishes for 1996
Ronald Wiemer
R.O.B. / ARCHIS
kerkstraat 1
3811 CV Amersfoort
The Netherlands
Thanks, Ron.
I'll take a look at your code. I have written a code
that has solved the problem of shared boundaried, as
I tested. I do have a problem to take concaves into
GRASS, which I didn't have time to work on it yet.
BTW, does youe code take care of concaves? For me I have
a problem to identify a point within the concave that required
by GRASS, if I understand GRASS correctly.
--Xin
In info.grass.user you write:
only).
Ronald Wiemer
R.O.B. / ARCHIS
kerkstraat 1
3811 CV Amersfoort
The Netherlands
