vect polygons to MapInfo
Has anyone done the other way - MapInfo -> Grass dig files?
Simon Cox
_________________________________________________________
Dr Simon Cox __ \
CSIRO Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ;-' \ Geodynamics
Nedlands, WA 6009 Australia ( \ Cooperative
      Phone +61 9 284 8443 + ___ / Research
      Fax +61 9 389 1906 L~~' "\__/ Centre
simon@ned.dem.csiro.au W
AGCRC info>> http://www.ned.dem.csiro.au/AGCRC/
I have a program to do this. However, like what I indicated
yesterday, I' having a problem to take a concave into GRASS.
If someone has a code to figure out a point within concanve,
I would appreciate it. Right it will do points, lines/polylines,
and convexes. There's one way to get around concave problem
that is to get centroid for every "regions" in MapInfo and
save such info in its mid file. In that way, you could just
simply use mid as GRASS dig_att.
--Xin
In info.grass.user you write:
Simon Cox
Dr Simon Cox __ \
