Vector to Ascii output
Joe Leone (Joe.Leone@per.dwe.csiro.au) writes on 11 Oct 94:
>I am trying to import map layers into a Graphic/Map package. The
>required import format is simialr to that produced by v.out.ascii ,
>but not close enough :frowning: .
>The format I require is as follows:- > >
>unique identifier x,y co-ordinate of pt within the polygon # of nodes
>(vertecies)
it should not be too difficult to modify v.out.ascii to do this.
Is there a library function to give a point-within-polygon?
If not, I believe that there may be a routine that says
"yes or no" about a point. [don't have the programming
manual on site right now]
Alternatively, assuming that we only have polygons in the map,
we could use v.digit to add Points and then think of some
clever way of labelling so that the transformation of
v.out.ascii output to your format could be done with awk.
Greeting again,
The problem with v.out.ascii is that output is split into line. For example the output below is from a square made of two line segments. ie it has two nodes.
ORGANIZATION: US Army Const. Eng. Rsch. Lab
DIGIT DATE:
DIGIT NAME:
MAP NAME:
MAP DATE:
MAP SCALE: 10
OTHER INFO:
ZONE: 0
WEST EDGE: 751.465
EAST EDGE: 3427.435
SOUTH EDGE: 1812.095
NORTH EDGE: 3612.905
MAP THRESH: 0
VERTI:
A 2
1893.95 1041.4
1897.78800991 2173.612922
A 5
1901.6 3298.15
3531.05 3305.8
3523.4 873.1
1893.95 1041.4
What I would like is ( apart from a point within the square ) is the following output
DIGIT DATE:
DIGIT NAME:
MAP NAME:
MAP DATE:
MAP SCALE: 10
OTHER INFO:
ZONE: 0
WEST EDGE: 751.465
EAST EDGE: 3427.435
MAP THRESH: 0
VERTI:
A 6
1893.95 1041.4
1901.6 3298.15
3531.05 3305.8
3523.4 873.1
1893.95 1041.4
Thanks
Joe Leone
