Hi Agus,
did you try v.line2area.sh?
It might be usable for this conversion.
I have imported a vegetation map of Europe.
Nevertheless, it was digitized as LINES, not
as polygons. Therefore, I have now a vector
map in which the lines should be attached
to make polygons. I've checked abd is not just
that each polygon is made out of on single line,
so it's not just a question of replacing "L"
by "A" in the ascii vector format.The question (and I suspect the answer...):
is there an automatic procedure to combine the
lines into polygons?, i.e., if we have:AAAAAAA
B A
B C
D C
DDDDDDD(where each letter is a line)
go to
2 polygons
Thanks (to both mailing list users and mailing list keepers)
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
alobo@ija.csic.es
http://pangea.ija.csic.es/alobo
