Plotting to the versatec from GRASS requires the use of sprint utility.
sprint converts sun raster files (the p.map output from grass) to vcgl
format for the plotter. sprint utility can be purchased from Xerox.
If you get sprint, i have written a plot script which assists in the plotting
from GRASS to the versatec via sprint. Basically it allows you to actually
plot at a chosen RF or plot width, center, choose # of copies, and will determi
ne
if the plot will fit within the allowed 42". Something the versatec driver its
elf
doesn't accomodate. Really.
Ps.map can only be used if you have some type of rasterizer software to
convert the postscript to a format ready for the versatec. We use Newsprint.
To use ps.map for large format devices you need to create a ps.devices file
for that. $GISBASE/etc/paint/ps.devices. I use the following data for E size p
lots
level: 2
page width: 34.0
page height: 44.0
top margin: 0.5
bottom margin: 0.5
left margin: 0.25
right margin: 0.25
resolution: 300
Hello Users:
I have a Versatec plotter model 8844. I am trying to plot raster maps from
grass using p.select paint=versatec (I have already compiled the driver and
shell) and after that the program p.map It start to work but when finishing I
have an error message that the program sprint not found. What exactly that
means?I am trying also using ps.map, I am trying to create a configuration file wit
h
large dimensions for the 44'' with, but I have an error in the scale and the
postscript file is corrupted. ps.map just works with small sizes devices? How
can I change that?Thanks in advance for your help
Roberto Bonifaz
Instituto de Geografia
UNAM
