Nandish,
This is a series of messages from several months ago on the list (see
below). Things may have changed, but it does not sound like it from
your message. Check the list archive as there were several other
messages at the same time on this subject.
Good Luck,
Ken Sibley
USDA-SCS/NCG "Hell, if you understand everything I say,
ksibley@ncg.scs.ag.gov you'd be me!" - Miles Davis
PS. If you know a Kelly Johnson working there at the Space Center
have her send me a message (female - age ~27).
Hi!
Recently, we set up xgrass4.1 on SUN Sparc IPC staion. It is up and
running OK. But, before we get the XGRASS menu, it displays several
(I could not count them!) warnings such as:Warning: translation table syntax error: Unknown keysym name: osfRight
Warning: ... found while parsing ' <Key>osfRight: forward-character()'
Warning: translation table syntax error: Unknown keysym name: osfUp
Warning: ... found while parsing ' <Key>osfUp: traverse-prev()'
Warning: translation table syntax error: Unknown keysym name: osfDown
Warning: ... found while parsing ' <Key>osfDown: traverse-next()'We get the Menu after all such warnings. I am wondering what these
warnings are about, and how to care take of them. Any help will be much
appreciated.Thanks,
Nandish Mattikalli
NASA/Goddard Space Flight Center, Code 974
Greenbelt, MD 20771
e-mail:> Hello Ken!
> >From info.grass.programmer it seems like you know how xgrass is
> working, so I would like to ask you a question.
> My name is Terje Midtboe. I have installed the
> new binary-version of grass4.1 on a SPARC station.
> We are using X11 windows-system.
> It seeems to work, BUT a lot of warning messages is showing up at the
> window where I started xgrass. I guess it is only a detail I need to
> fix. Can you explain how to make the program run
> without these warnings.
> Example of the warnings:
> /usr/local/grass% xgrass4.1
> osfActivate
> Warning: ... found while parsing '<Key>osfActivate:
> ManagerGadgetSelect() '
> osfSelect
> Warning: ... found while parsing ' <Key>osfSelect:
> Warning: translation table syntax error: Unknown keysym name: osfHelp
> Warning: ... found while parsing ' <Key>osfHelp:
> ManagerGadgetHelp() '
> osfBeginLine
> In the spring of 93 I imported an earlier compilation of xgrass4.1
> that worked fine, without any warnings.
> Terje
> Terje Midtboe
> Division of Surveying and Mapping Phone: +47 73 59 45 83
> University of Trondheim Fax: +47 73 59 46 21
> N-7034 TRONDHEIM E-mail: terjem@iko.unit.no
> NORWAY
> ------- ------- -------Terje,
I think we just figured this problem out with a little help from our notes.
The following is from a message by Andrew Hertz:>My understanding is that the openwindows XKeysymDB will not work, you
>want the OSFmotif key mappings. I used the XKeystmDB that's in the xgrass
>source directories ($GIS/src/xgrass). If you've only downloaded the
>binaries, I've put a copy of the XKeystmDB in grass/incoming at
>max.cecer.army.mil. I believe this file MUST be placed in /usr/lib/X11
>because the static binaries have Motif embedded within them and they
>are looking explicitly for /usr/lib/X11/XKeysymDB.
>(You can check this by issuing the command:
> strings xg* | grep XKeystmDB
>in the directory where the xgrass binary executables reside.)
>Changing your path won't help you in this case.
>I hope this helps...
>Andrew Hertz
>hertz@geog.psu.eduMost of this seems to be correct, but the XKeysymDB file does not
necessarily need to be in /usr/lib/X11. What we found is that
you must place the XKeysymDB file in the directory that returns from
the strings command. We were working on xdigit specificaly (note: using
strings xg*... will not catch xdigit. Use strings xdgit ... for this)
and our path is /grass.src/X11R5/lib/X11/XKeysymDB. This seems to
indicate that it requires the keysym file to be in the exact location
when running that existed when being compiled even if it is a different
machine.If you have any further questions I will try to help.
Ken Sibley
USDA-SCS
