WEXITSTATUS
Peter Sincak wrote:
I am just trying to make xgrass - almost passed only on the end
of the procedure - it comes the missing of the following :
when I am building xgrass - the last stage
Unresolved symbols still remain.
symbol referenced in
_WEXITSTATUS /dd2g/sincak/grass4.1/grass4.1beta/src/xgrass/libes/
                    LIB.convex/libXgi.a(system.o)
ld: ERROR - incomplete load
ld: No executable produced.
well - I understand it that WEXITSTATUS - I miss - I suppose that it
is a matter of UNIX (CONVEXOS 10.1) not grass & probably from X-area.
Can anybody
help me where I can find this procedure ? ?
  Peter Sincak, Ph.D.
  Kosice, Technical University of Kosice, Slovakia - Central Europe
  Department of technical Cybernetic & Artificial Inteligence
  sincak@ccsun.tuke.cs FAX: 0042-95-32748 Voice: 0042-95-57864
I had trouble with WEXITSTATUS while compiling xgrass for an RS6000.
I'm way over my head, here, but this is what I figured out:
   Caveat: I managed to get Xgrass to compile, on my RS6000, but
   it doesn't run properly. I'm not much of a UNIX programmer,
   these are just my observations, and they might be faulty.
   HAS ANYONE GOTTEN XGRASS TO WORK ON AN RS6000?
WEXITSTATUS(x)
is a macro defined in the standard include file sys/wait.h, and on
the RS6000 it is redefined in sys/m_wait.h if you use the BSD compile
options. In the Xgrass source code (or is it with the grass src/include
files) there is an include file called std_incs.h. It #includes wait.h,
which may or may not #include m_wait.h depending on how your computer
tries to deal with the many flavours of UNIX incompatibility.
The incompatibility seems to be that some versions of UNIX have a
variable "status" defined as an integer, and some define it as a
union. How WEXITSTATUS is defined depends on how "status" is defined.
WEXITSTATUS is a macro that returns a value based on the value of
"status". Here is what it looks like, from the m_wait.h of an RS6000.
Here status is a union, and it is the variable x in the macro below.
This is the BSD format, apparently.
/* evaluates to the low-order 8 bits of the child exit status */
#define WEXITSTATUS(x) (int)(WIFEXITED(x) ? (((x).w_status >> 8) & 0xff) : -1)
If your computer uses POSIX, then (I gather, from the include files) the
variable status is an integer, and the macro WEXITSTATUS will look like
this: (from sys/wait.h of an RS6000)
#define WEXITSTATUS(x) (int)(WIFEXITED(x) ? (((x) >> 8) & 0xff) : -1)
So, you might be able to define one or the other in the offending C
file: I think it is probably system.c in Xgi or Xgl.
Tim.
  Tim Martin * Canada, yes. Mexico, yes.
  Spatial Information Systems * But in that little gap
  University of Alberta * in between, zippo.
  martin@ulysses.sis.ualberta.ca * - Bob Geldof
