Dear Brent, dear list-subscribers
Well, now I switched back to Java2SE SDK 1.4.2_11, and the persisting warnings changed from NoClassDefFoundError to UnsupportedClassVersionError, e.g.:
14:24:39.207 WARN!! Exception for /geoserver/
java.lang.UnsupportedClassVersionError: org/apache/jsp/index_jsp (Unsupported major.minor version 49.0)
at...
hmmmmm....?
Von: Hebel Bernd
Gesendet: Mittwoch, 1. März 2006 10:42
An: 'Brent Owens'
Betreff: AW: [Geoserver-users] java.lang.NoClassDefFoundError
... not yet tried, but I will and tell you later.
Thanks and regards, bd
Von: Brent Owens [mailto:brentowens@anonymised.com]
Gesendet: Mittwoch, 1. März 2006 03:59
An: Hebel Bernd
Betreff: Re: [Geoserver-users] java.lang.NoClassDefFoundError
It might be a Java 1.5 issue. Have you tried with java 1.4 and seen the same errors?
Brent Owens
(The Open Planning Project)
Hebel Bernd wrote:
Using Geoserver 1.3.0 on Sun Solaris 8 using JDK 1.5.0_06 and having
all environment variables set as followsJAVA_HOME=/usr/java
export JAVA_HOME
GEOSERVER_HOME=/export/disk024/geoserver
export GEOSERVER_HOME
GEOSERVER_DATA_DIR=/export/disk024/geoserver/conf
export GEOSERVER_DATA_DIR...I keep obtaining stacks like:
10:54:34.637 WARN!! Error for
/geoserver/wms?LAYERS=tiger:giant_polygon,tiger:poly_landmarks,tiger:t
iger_roads,tiger:poi&FORMAT=image/png&TRANSPARENT=TRUE&HEIGHT=406&REQU
EST=GetMap&WIDTH=810&STYLES=,&SRS=EPSG:4326&VERSION=1.1.1&BBOX=-74.0
2924949245278,40.70060354838641,-73.9883552568504,40.72110115289822
java.lang.NoClassDefFoundError: org/vfny/geoserver/servlets/AbstractService$ServiceStrategy at ...or
11:26:01.037 WARN!! Error for
088023746516,40.70060354838641,-73.96790813904921,40.72110115289822
java.lang.NoClassDefFoundError at...what goes wrong?
many thanks for your help, bd
This SF.Net email is sponsored by xPML, a groundbreaking scripting
language that extends applications into web and mobile media. Attend
the live webcast and join the prime developer group breaking into this new coding territory!
http://sel.as-us.falkag.net/sel?cmd=k&kid0944&bid$1720&dat1642
Geoserver-users mailing list
