No, sorry, S-PLUS is not free. Included below is info about it.
As an aside: In the past someone in the GRASS community created the GRASS
"s.menu" commands which facilitated interaction between S-PLUS (or S?) and
GRASS. But I believe it was based on a much older version of S-PLUS and would
not work with the current version of S-PLUS. I really don't know much at all
about s.menu, maybe it has been updated (the info I have is from 1991)?
Contact Info:
StatSci
1700 Westlake Ave N
Suite 500
Seattle, WA 98109
(206) 283-8802
(800) 569-0123
mktg@statsci.com
http://www.statsci.com/
Below is a portion of the data sheet for S-PLUS 3.2. Version 3.3 for Unix
will be available later this month.
S-PLUS
Version 3.2 for Windows and UNIX Systems
S-Plus incorporates the S language developed at AT&T Bell Labs.
Features
Interactive analysis, with step-by-step feedback
Built-in, true object-oriented language
S-PLUS supports object classes, inheritance, generic
functions, and methods
Operators and functions work on scalars, vectors, arrays
Structured language, including for, while, next, repeat,
break
Logical operators, including >, >=, <, <=, ==, !=, &, if
else, all, any
Sophisticated operators for assigning, extracting,
replacing parts of objects
"list" object contains structured arrays of dissimilar
items
Write your own functions for specific analyses
Modify any of the 1,650 provided functions
Interface with C and FORTRAN programs
Use as front-end for commercial libraries (IMSL, NAG, etc.)
Dynamic (run-time) and static loading of user-written C
or FORTRAN programs
Dynamic loading of Dynamic Link Libraries (DLLs) in
Windows
Interface with operating system
Spawn subprocesses
Access to operating system editors
Pass data to/from operating system and other applications
Input/Output
ASCII files
Input data from keyboard
Input binary files through user-written FORTRAN or C
programs
Interactive data editor
PostScript and HPGL output
Support for all MS Windows printer drivers
Help and Documentation
Interactive point-and-click help system
Extensive documentation
Command line recall and editing
Telephone and e-mail Helpline
Classic and modern functions insure penetrating analysis and
best fit
Basic statistics
Descriptive summary statistics
Student's t-test
Chi-square test
Wilcoxon rank sum test
Binomial test
Mantel-Haenszel test
Probability distributions
Multivariate statistics and graphics
Hierarchical clustering
k-means clustering
Model-based clustering
Tree classifiers
Log-linear contingency table analysis
Minimum spanning tree
Principal components
Factor analysis
Canonical correlation
Multi-dimensional scaling
Chernoff's faces
Star-symbol plots
Dendogram plot of cluster-tree
Scatterplot matrices
Mathematical computing
Vector and matrix operations, +, *, etc.
Eigenanalysis
Invert matrix and solve linear equations
Singular value and QR decompositions
IEEE special values supported
Quality control charts
Shewhart charts
Cusum charts
Charts based on xbar, s, np, p, c, u
Regression and ANOVA
Linear least squares
Nonlinear least squares
Balanced and unbalanced ANOVA
Stepwise regression
Least trimmed squared residuals regression (high
breakdown point robust regression)
Generalized linear models
Generalized additive models (GAM)
Residual deviance (for model comparison)
ACE and AVAS regression models
Projection pursuit regression
M-estimates of regression
Tree-based regression
Survival analysis
Cox regression with time-dependent covariates
Kaplan-Meier and Fleming-Harrington curves
G-rho survival curve tests
Time series/signal analysis
Autocorrelation
Autoregression models (classical and robust)
ARIMA models
Linear filters
Complex demodulation
Spectral analysis
Fourier transformations
Smoothing: wide variety of robust and classical smoothers
and filters
Integrated graphics help you determine which analysis methods to apply
Interactive graphics/Data visualization
Multiple graphics windows
Location of graphics via mouse
Point identification using mouse
User-definable color maps
Interactive color map save/load
3D data spinning
Scatterplot matrix brushing with optional marginal
histogram
3D plotting
Contour plot
Data spinning
Mesh surface with user-selected perspective
Image plots (pixel data representation, color or gray scale)
2D plotting
X-Y scatterplots
Time series plots
Box plots, pie charts, histograms, bar plots, dot charts
Overlay multiple plots or display side-by-side
Log and linear axis scaling
Control over line style, marker type, colors, labels,
tick marks, text, fill pattern
USA maps
General mapping functions
System Requirements:
Windows System Requirements:
A personal computer with an 80386 or higher processor
with math coprocessor
8 MB of RAM
Hard disk with 14 MB of free disk space for minimum
installation or 25 MB of free disk space for complete
installation
VGA or higher-resolution graphics adapter and compatible
color or monochrome monitor
Printer with Windows-supported printer driver
Microsoft Windows operating system version 3.1
MS-DOS operating system version 5.0 or later (version 6.2
recommended)
UNIX System Requirements:
SUN Sparc, IBM RS/6000, Hewlett-Packard 9000-700, Silicon
Graphics IRIS, DECstation, DEC Alpha/OSF
16 MB of RAM
Hard disk with 55 MB of free disk space
UNIX graphics devices supported:
X-Window system (Motif or OPEN LOOK)
Various graphics terminals
Line printer/character graphics
Hardcopy: PostScript, HP Laserjet, HPGL, Color PostScript
pixel image graphics
UNIX Programmer's Toolkit:
StatSci offers an optional programmer's toolkit,
S+INTERFACE, to aid in the development of a menu-style
interface to S-PLUS functions, or for interfacing S-PLUS to
C applications. Please call for more information.
Support Services, Training and Consulting:
We're committed to helping our customers use our products
successfully. We offer a software support and update program
and a telephone help line, as well as support via e-mail or
fax. We can conduct training courses at your location or
ours. Consulting services are also provided on applied
statistics or custom application design using S-PLUS.
Volume, Academic, and Non-Profit Pricing:
Volume discounts and special pricing for academic
institutions and non-profit organizations are available.
Please contact StatSci at (800) 569-0123, or your local
distributor, for more information.
