Does anybody know why an eccentricity or flattening coefficient
of zero is considered an error? It makes it impossible to define a
sphere of constant radius as one choice in the ellipsoid table. I
notice that such a choice appears in the default ellipsoid table
($GISBASE/etc/ellipse.table) but is commented out. If you un-
comment it and then run something that uses that table (like
m.datum.shift), it gives an error referring to that line. The error
comes from function get_a_e2 in get_ellipse.c of libes/gis, which
complains if the eccentricity (squared) or flattening value is
(less than or) equal to zero. Should that test be changed to
less than zero only, or would that cause problems elsewhere?
jim /--\
______________________________________________________________________
Jim Aanstoos Internet: aanstoos%louie@rcc.rti.org
or aanstoos%louie@rti.rti.org
Research Triangle Institute
PO Box 12194 Phone: 919-541-6890
Research Triangle Park, NC 27709-2194 Fax: 919-541-6515
