Writing GRIB/NetCDF/HDF
Hi Arlindo:
Thank you very much for your wonderful script lats4d ! I tried it on a PC as
well as HP-UX 10.2 and it works great -- freeing up lots of disk space !!
A minor problem when I use this script interactively is that I need to get out
of GrADS every time I run the script. Even a 'reinit' doesn't solve the
problem. Of course the shell script 'lats4d' is a good way out, but sometimes
one needs to work interactively. Further, in the interactive mode I find that
lats4d ignores the GrADS setting 'set levs ...' given prior to running lats4d;
it writes all the levels. If one wants to write only subset of the levels, one
has to use the lats4d option 'levs'.
Kumar ...:slight_smile:
