I'm just getting started with GRASS, running it on an HP. It was
installed by a techie who has since left. I am following the Leicester
tutorial online. In response to
GRASS-GRID > d.mon start=x0
I am getting the following message:
Error: could not execute '/users/grass/driver/XDRIVER'
Please start graphics monitor <x0>.
Error - Graphics monitor <x0> not running!
The /driver subdirectory is empty and I'd like to avoid downloading all
the source files to find a solution. What's the best way to get past
this error?
Thanks in advance to anyone who can help.
Paul R. Koch
NRC Fellow
Office of Hydrology
National Weather Service
Hi Paul,
this error?
check in your subdirectory $GISBASE/src/CMD/lists if you have copied the
file local.example to local and uncomment the following line
src/display/devices/XDRIVER
if you want to run xgrass uncomment also the xgrass stuff.
Here you can also add other sources that you want to compile at the same
time. I hope this will help you out!
Bart
| ir. Bart Cosyn |
| VLIR-project Tunisia |
| Laboratory for Hydrology and Water Management |
| University of Gent |
| Coupure 653, B-9000 Gent |
| Belgium |
| Tel: +/32/9/2646137 |
| Fax: +/32/9/2646236 |
| E-mail: bcosyn@allserv.rug.ac.be |
| URL: http://taoren.rug.ac.be/ |
