X terminal and Grass
We're running a Tektronix XP29 (1280x1024) off a Sparc2 and sometimes
a 3/60. It works well and looks pretty good, but is not as crisp as I'd
like for text applications.
We tested an older (early 1991) NCD terminal and rejected it because
the resolution wasn't high enough. Since this time they've introduced
some new models, though.
All vendors we had contact with were willing to loan us a terminal for
tests. You should try this.
Hal Mueller If guns are outlawed, only the government
hmueller@orca.tamu.edu will have guns.
