xdigit runtime error -- Help needed
Hi, After compilation of xgrass on USL system, xdigit does not work and each
time when I key in xdigit under grass prompt, I will get following error
msgs:
  X Error of failed request: BadValue(integer parameter out of range
              for operation)
  Major opcode of failed request: 53 (X_CreatePixmap)
  Value in failed request: 0x0
  Serial number of failed request: 413
  Current serial number in output stream: 415
Can any experienced X-Window friends might pass me some hint? Where the bugs
will be?
    Thank you for any help
      PK Lin
      E-mail pklin@cerf.net
      Tel: (617) 942-1655
In info.grass.programmer you write:
If you find out what caused this, I would like to know. I get the same
error running xgrass on Solaris 2.x, but I get it when I try to start xdigit.
msgs:
            for operation)
[Jim] pirzyk@uiuc.edu ------------------------------------------- __o
TAC & GrassNet System Administrator, US Army Corps of Engineers _'\<,_
Construction Engineering Research Laboratories, Champaign IL USA (*)/ (*)
