Xgen sliders
Hello all,
I'm having a problem with xgen that is driving me to distraction (although xgen
itself is really an incredible piece of software!). Anyway the problem comes in
trying to use the slider object and retireve the value that is set. As far as I
can tell from the documentation, the script listed below should work, but
unfortuantely, the "accept" button causes the program to behave erratically and
finally to crash with a segmentation fault.
The real issue for me is retrieving the value set by the slider and storing it
in a shell variable for use in a command line argument and for later use in the
xgen script. Any help or suggestions would greatly appreciated.
John Cartwright
johncc@picea.cfnr.colostate.edu
/* XGEN script to receive user input via text entry and slider object.
#define DarkFG foreground:NavajoWhite
#define LightBG background:black
#define DarkBG background:NavajoWhite
#define LightFG foreground:black
DarkBG
LightFG
font:"*adobe*helv*r*normal*14*"
/* beginning of the first environment... */
environment firstEnv
  initialshells:"Main"
  commandboard Main
    titlestring:"Main Window"
    x:0
    y:0
    background:IndianRed
    setOPTIONS:""
    setWSHD_DESCRIPT:""
    setFILE_NAME:""
    setMAP_PREFIX:""
    separator I1
           separatortype:singleline
      x:0 y:50 width:500
    label "Enter Watershed Description"
      alignment:center
      x:0 y:75
      width: 500
    textentry t2
      x:0 y:100
      width:500
                slider rain
                        titlestring:"Set Rainfall Amount in Inches"
                        font:"*adobe*helv*med*r*normal*14*"
                        x:0 y:150 foreground:black background:IndianRed
      decimalpoints:0
      orientation:horizontal
      startvalue:0
      minimum:0 maximum:50
                button "Accept"
      x:0 y:300 width:250 alignment:center
      height:60 popdown:Main popup:showResults
    button "QUIT"
      x:0 y:400 width:250 alignment:center
      foreground:IndianRed height:60 popdown:Main
      exit:0
  commandboard showResults
  setRESULT:"[rain]"
    label "Results Summary"
    x:0 y:0 width:350
    label "rainfall amount = "
    x:0 y:75 width:50
    label value
    x:50 y:75 titlestring:"$RESULT"
    font:"*adobe*helv*bold*r*norm*14*"
    alignment:center
    separator a1
    separatortype:doubledashedline
    button "OK"
    x:0 y:150
    popdown:showResults popup:Main
