In an E-mail message, Teresa Hansen wrote:
Hi all you xgen user's (and creators - Kurt)
I have written an xgen script, and now I want to modify some of
the pulldown menus. Presently on the menus there is a label a
static button and a dynamic button. When this menu is in view
there is a scroll bar at the right side. When using the scroll-
ing device the label and static button scroll up, out of view of
the menu. This is not a great problem, mostly a peculiarity to
my users who would like to see the label and static button remain
in view at all times, while still being able to scroll through the
other items lited (in the dynamic buttons). Does anyone have a
solution to this?Teresa Hansen
lewis!teresa@cerl.cecer.army.mil
206-967-5337Thankyou!
In order to prevent the labels and static buttons from scrolling out of view
when you use the scroll bar, you should use the xgen tool called "list".
There are several types of lists:
Single (listtype:single) One selection at a time by clicking with the
mouse.
Multiple (listtype:multiple) Several picks allowed by clicking with the
left mouse button. All selections remain highlighted.
Extended (listtype:extended) Several picks allowed by holding mouse
button down and dragging. All selections remain highlighted.
Browse (listtype:browse) Similar to extended except that only one
file is highlighted at a time.
The following xgen script can be used as an example:
#define cent alignment:center
#define back background:white
#define fore foreground:white
environment start
initialshells:"One"
sethome:"!cd"
commandboard One
x:800 y:100
label "This is an Example"
x:0 y:0 cent back ;
button abc
titlestring:"Exit"
x:0 y:30 width:100 fore cent
exit:0 ;
list reporter
x:0 y:70
updatefrom:"!ls $home"
visibleitems:11
listtype:single
listseparator:"," ;
/* The button below is only an example */
button "Select"
x:0 y:280 width:80 alignment:center
setFILE:"[reporter]"
runforeground:"cd $LOCATION/paint; if test \"[reporter]\"; then echo 'vector [reporter]' >> $FILENAME; fi"
popdown:One
popup:Something ;
________________________
Paul Loechl loechl@zorro.cecer.army.mil
USA CERL 1800-USA-CERLx668
