Xgrass - compilation and Motif
Hello!
I have trouble getting the xgrass-part of grass4.1 compiled on my system.
I get the following message before the process terminates.
cc -O -I/usr/include -D_NO_PROTO -I/usr/local/grass/grass4.1/src/include -c Matrix.c
/usr/local/grass/grass4.1/src/include/Matrix.h: 121: XmRStringArray redefined
"/usr/local/grass/grass4.1/src/include/MatrixP.h", line 252: syntax error at or near variable name "XmManagerClassPart"
"/usr/local/grass/grass4.1/src/include/MatrixP.h", line 415: syntax error at or near variable name "XmManagerPart"
"Matrix.c", line 75: matrix undefined
"Matrix.c", line 153: warning: undeclared initializer name XmManagerRec
"Matrix.c", line 153: syntax error at or near symbol )
"Matrix.c", line 154: syntax error at or near type word "char"
"Matrix.c", line 486: warning: undeclared initializer name xmManagerClassRec
"Matrix.c", line 547: too many initializers
"Matrix.c", line 548: too many initializers
"Matrix.c", line 549: too many initializers
"Matrix.c", line 550: too many initializers
"Matrix.c", line 575: fatal error: too many errors
*** Error code 1
make: Fatal error: Command failed for target `OBJ.sun4/Matrix.o'
Current working directory /usr/local/grass/grass4.1/src/xgrass/libes/Xgi
*** Error code 1
make: Fatal error: Command failed for target `all'
GISGEN failure at STEP: src/xgrass/libes
Can someone tell me if grass4.1 requires a particular version of Motif,
(I use version 1.2.4) or a particular X11 release (I use release 5), or
if this is caused by something else.
Thank you in advance!
Trond Rinde
