XGRASS compilation
One point is that there is a file (xgen.bin.sun.Z) in 'moon' \incoming -
I wonder if this is something to do with XGRASS, as I've got the
Postscript manual and it mentions 'xgen' program ??
Since questions about xgen seem to draw deafening silences, I'm left
wondering if anyone else is using it. Or is tcltk considered the way
to go?
Re xgen: I have a number of questions. For example, can you pass
variables into an xgen script? and How do you address a cell in an
xgen table using variables?
- Bob (black@calspan.com)
In info.grass.user you write:
to go?
I am still using xgen (writing a new script today, as a matter of fact).
I saw your question about xgen table, but didn't respond since I
haven't played with tables. Meanwhile, passing variables is doable
(but like other things with xgen, sometimes you have to go about
it in a round-about way).
One way is with shell environmental variables. Another method I use
which may or may not be usefull to you (depending on what you are
doing) is making use of the fact that an xgen script is first read
by cpp (the C language preprocessor), so one can make use of some
of its capabilities. For instance, I have a header file wherein I
set up a bunch of parameters like colors, fonts, x-y locations, and
such that can be used by a number of xgen scripts by using the cpp
#define and #include references.
chris
